    To dismiss this notice
    click the top right X.
Aftermarket Intakes
Aftermarket Intakes
Niedhogg
Old Time Jeeper
Thor, Iowa
'79 Jeep CJ7 Renegade with 304ci V8, TH400 auto, Quadratrac T-case, Stock 20 and 30 rears with no mods yet, not sure of the gear ratio.. 4" Softride Superlift, w/widetrac shock towers and 35x12.50x15 BFG Mud-Terrains
'76 CJ5, 232 ci, T-150 3-speed, D20 T-case, Corp. 20 rear w/full float axles and lockout hubs and Detroit auto locker, D30 front w/lockout hubs, gear ratio is unknown..
So my old AMC 304 2bbl intake had a threaded fitting for what I believe is the crankcase vent at the back of the intake, which was plumbed to the back of the carburator base plate.. my new Edelbrock 4bbl intake has a rather large 1"-1-1/4" non-threaded hole where that used to be. I assume I'll still need to vent the crankcase, so what do I use here??
Summit Racing has some Edelbrock 11/4" rubber bushings that a PCV valve will fit in. Then just run a hose up to carb.
Thanks Purple... :)
$40.00
  20.0%
