Altenator help
Altenator help
Jimbos76cj
Full Time Jeeper
St.Cloud FL
83 CJ-7.. 4" YJ springs front rear, J-10 44 front/AMC 20 rear,6 cy auto dana 300 35' bfg Done and gone!!
Ask me about my head light upgrade harness!!!
I would start with new brushes but there is no reason I can say the old ones are bad.:cool:
Thanks busa. Where did you find that kit at? When ever I go through one I normally replace the bushings, but wanted to see if any thing else was bad before orderiing the brushes. I've got another one on the shelf. I think I'm gonna have tested. I'm not sure if the parts monkey was doing it right. He needed a lot of help setting it up.
I dont know why it didn't post but I wrote this long dissertation about the alternator problem and parts store retard. Thanks Busa for the link. I was hoping that it had the kits there to buy but only had directions on how to rebuild, which for shiggles I read through even though I was confident that I knew how to do it. Come to find out I had a wrong bolt that held down the diode to the brush holder and was grounding it out. I swapped the bolts, took it back and had to arm wrestle the guy to test a shelf alternator since both of the ones I bought in showed a bulb failure (or something like that) Sure enough his machine was bad. I hit the next closest store and they both worked great.
