Alternator Help
Torxhead
Always Off-Roading Jeeper
Have a neighbor with a hot rod '56 Ford truck purchase a 150 amp alternator from Jegs and has issues with charging at idle. It was purchased to help the aftermarket air conditioner run and still keep the alternator charging. The specs say it begins the charge at around 880 rpm, it is also a one wire type hooked directly to the battery, I guess hot rodders don't like a lot of wires under the hood. I am thinking it is a reworked GM 12si alternator. From what I understand it is required to burp the throttle to get it charging. I am going to try and convince him to run the alternator charge wire to a junction box with wires from there returning to the battery and other major amp draw connections. I got this plan from looking at a web page(MadElectrical.com - Electrical Tech) which is about alternators. I am looking for other suggestions on how to best wire this monster up. It is already mounted in the truck.
