AMC 258 Engine/Head ID help
SaltyNole
- North of Dallas, TX
- '81 CJ-7 Laredo, '80 AMC 258, T176, Dana 300, Dana 30, AMC 20
I am looking for a little engine/head ID help.
Looks like the PO swapped out the engine in the '81 Jeep CJ I just bought. I also would not put it past Jeep to have dropped in a left over engine from 1980.
What made me notice is the valve cover gasket I bought for the '81 model is straight on the passenger side. However, my head and valve cover both have some curved cut outs at each spark plug.
This started my research on engine and head casting/stamping numbers.
My engine block has a stamping code of 003C04 on the passenger side and casting code of 3235077 on the driver side. In my research, I have seen mixed information on this stamp code, but there is some information that shows this being a AMC 258 i6 / 4.2l block that was manufactured in March 4, 1980.
The casting code also indicates that this is a 1980 AMC 258 i6 / 4.2l block.
I also looked at the head casting code since the valve cover had to come off and that code is 3227258-2. Again from what I am seeing this is a head that was used on the 1980 AMC 258 i6 / 4.2l blocks and prior. However, it seems that only in 1980, the temp. sending unit was at the top rear of the head, and that is where mine is.
I hope someone has a little better insight than I do on this subject and can enlighten me a bit more. Otherwise I will assume I am correct in my assumption this is a 1980 model AMC 258 i6 / 4.2l with a 1980 model head.
