Amc 304 fuel pump??? Help
Hitman1881
- Central Iowa
- 1981 cj7, 304 ,4 speed,twin sticked d300, amc20 with solid axles, Dana 30 , 33-12.5 tires, PsC BFH Front bumper with 8500lb Ramsey wench.
Well tonight I got my power steering gear back ( another story) and got that put in when I started the cj to bleed the power steering system I started to smell fuel. I looked underneath and had major gas leek. Started digging and found that the gas was pouring out of this hole in the side of the fuel pump casting. It really sprays out with engine running and just slow drip when not running. Attached is a photo of where it is spraying out. It is the hole on the right side just left of the fuel pump mounting bolt.
So my question is what the
?I have not had the jeep running for two weeks because the steering has been apart and it wasn't leaking fuel before. Why would this be lee king and what do I do to fix, replace fuel pump? Thanks in advance for any input.
