AMC 360 timing cover
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
After a few posts on the subject a used but recently rebuilt AMC 360 motor is sitting in my garage waiting to be installed in my 1975 CJ5 . Before being installed I'm doing what I believe is prudent work on the engine.
The water pump is bound up so a new water pump is on its way. With that being the case and knowing the issues AMC engines have with the timeing chain and distributor drive gear I would like to remove the timing gear cover. I think I'm okay, but the gasket set comes with many gaskets associated with the oil pan. Does the oil pan need to be removed when the timing cover is removed?
Michael
Michael
