Another Steering Wandering Psycho 65mph Question!
Techlight
- Media
- 1
- California desert
- 1984 CJ7: 4.2l i6 (mild cam), Team Rush, Howell TBI, T5, D300, D30-front, AMC20-rear, 33/10.5/15 BFG A/T's........................
1964 Kaiser CJ5 (sold),
1960 Willy's CJ5 (sold)
I know this question has been done before so I won't bore you with too many details...but I was curious if slop in the steering shaft can cause poor steering as well. And if so how and can someone explain how much slop is too much etc.
Up around 60ish my Jeep rides fine, no bump steer, straight as an arrow, but if I'm hit by a gust of wind or have to make sudden steering it gets into this situation where it feels like I'm over-correcting even though I'm not. Kind of this back and forth until my speed is reduced...this is usually when my heart begins to beat as well haha. Kinda feels like I'm turning the wheel and nothing is happening for about 2 inches and then "steering gets applied" all of a sudden. I can drive my way out of this without reducing my speed my making very slight corrections, but I feel as if I got in some dangerous position (needing to swerve or a flat tire) I'd be done for and the new motor and money i've spent will be worthless, lol. Also I have noticed that my ride does not return to center on it's own if that's of any consequence.
I never got to drive the jeep before I overhauled a ton of stuff on it so i have no idea how it handled before. Unfortunately, I have touched everything that could cause this problem: 1 inch body lift, spring and shackle bushings, swaybar bushings. The ball joints feel fine to me but I haven't checked the steering linkage. I also have not had the alignment checked. It just feels like there is too much response in the steering even though there's a lot of slop on the wheel.
So that's a long way to my questions but...is there a way to check my steering shaft properly? And can this cause what I'm describing.
Also can my old tired springs cause this?
And while we're at it does anyone have an opinion on the heavy duty omix steering shaft? Or am I better off with the Borgeson one with the fancy vibration dampening?
Thanks for putting up with this steering question haha ...I'm sure my next stop will be to an alignment shop just to rule that out.
