anybody got the stock dimensions?
kickitandholdit
Old Time Jeeper
Savannah, Georgia
'53 CJ3B
Im looking for the stock dimensions of the cj. (body-ground, axel-frame, length of shackles)
Im trying to find out how much lift I have. Im clearing new 36" 12.50" swampers with room to spare.
Many thanks. :chug:
I am pretty sure if you put a straight edge from your spring main eye bolt to the spring front shackle bolt then measure down to the top of the axle housing from that straight edge, that will be your lift height for the springs. The shackles should be about 3.75 inches from bolt to bolt so what ever extra length you have, cut it in half and add to your spring lift number. Then add what ever body lift pucks you may have there is your total lift.
Again I am going off of memory here and someone may correct me if I am wrong.
Early CJ5 heights
