Anyone running 33x10.5 with a 2.5" lift?
TN farmer
Brownsville, TN
1982 CJ7 renegade with 4" lift and lockers
Has anyone run a 33x10.5 tire on their jeep and whats the least amount of lift you have to have? Thanks
Mine has 33 x 12.5 on it with a 2.5 in. lift and some aftermarket shackles. The shackles add another 1/2 in. Im using 10 in wide rims. There is some rub under full compression.
What does "Deja vu" mean I did a search and could not find anybody that was running a 10.5" wide tire. Do you know somthing I don't?
He knows what Deja vu means:laugh:
I have 2.5 lift on the springs and went with another inch on the body to carry 33's but you may be able to run 8 or 10 inch wheels to get enough offset to make it drivable. A lot will depend on how far off camber you go.
Speaking of which.
Is there a sticky on this very subject with a good common sence discussion on the ups and downs of lift variations and what you can expect to gain from them??:confused:
inquiring minds want to know!:cool:
Of course if we lost this topic for discussion it would eliminate 20% of the posts.:eek:
I ran 33x14.50x15 with a 4" superslift and only had scrub at full lock.
So a 4" with a 12.50 or 10.50 would be perfect as long as your offset wasn't weird.
