ARP Head Bolts
Purple77CJ7
Full Time Jeeper
- Media
- 36
- Solutions
- 1
- Loveland, Colorado
- 1977 CJ 7; Amc 401 .30 over, Howell TBI, modified Dana 20 with Terra Low gears and twin sticks, NV 4500 5-speed, modified Dana 30 and Amc 20 both with 4.56 gears (narrow track), ARB air lockers front and rear, SSBC rear disc brake conversion, MICO Brake park brake, Navaho brake booster/ master cylinder, PowerTank CO2 tank.
I ran in to an issue and thought I would share. I had my heads reworked for my AMC 401 engine and reinstalled with ARP head bolts. The bolts are fine, but the problem I ran into was the headers hitting the bolt heads. The ARP's install with a washer that the stock bolts don't use, so the bolt heads stick up just a little more. I had to grind some relief areas to clear the bolt heads on the header flanges. I use Edlebrock shorty headers. Other brands may be ok on clearance. Just something to think about.
