Axle Shaft Install Question
jalfonso1
Hey guys,
I'm in the process of changing the bearings and oil seals for my rear axle. (Dana 44 Flanged) I took the shafts to a machine shop to have the bearings pressed on and now I'm ready to put everything back together but ran into an issue with the outer oil seal. It seems as though they are not seating correctly and there is about a 1/2 inch gap between brake backing plate and flat part of the axle housing.
The bolts do come through enough to put the nuts on and start tightening down, but I don't want to tighten down that way and break something if that is not the correct way.
Is the oil seal supposed to slide into the brake backing plate middle hole, or does it just press against the edge? If that is the case, I'm not sure it will as it seems a couple millimeters too wide. The seal is the exact diameter of the bearing, so I know it is the correct part.
I attached a photo for reference.
Any ideas?
Any ideas?
