Axle shims- how much is too much
Bucks86Renegade
- Middle TN
- Restoration in process:
4.0L I6, Aw4 tranny, D300 transfer case, Dana 44 rear axle, Dana 30 front axle, 4.09 gears;
Original color black with (soon to be) '86 blue decals (3 shades).
Using tub from an '89 Wrangler
Hello,
In process of building a CJ7 :
I've installed a 4.0L I6, an AW4 tranny, a 2.5" lift w/ a 1" body lift. Dana 44 rear, Dana 30 front, 4.10 gears.
I know there are others who have the AW4 tranny in their CJ- what degree shims did you use on the rear axles?
It's looking like I'll need 6 to 8 degrees and I'll need to shorten my rear driveshaft as well. What are the cons to using shims?
Anybody recommend a maker of custom driveshafts for the front?
Thanks a lot.
Thanks a lot.
