Axle swap nightmare
Jinx
- Nicoma Park, Oklahoma
- 79 CJ5 304 (my brides), 83 CJ5 304 (mine), and... and 77 CJ7 parts jeep.
Ok I need help here. I own a 83 CJ5 that originally came with a straight 6 with 4 speed tranny, I removed it and put in a AMC 304 (runs great) with a T-150 3 . Only problem is now my gear ratio was way off (2.23 I think). So to try to fix this problem I had a kid from the local auto vo-tech swap out both front and back axles that have a 3.54 gear ratio. I decided to swap axles thinking it would just be easier in the long run because I have a 76 Cj that I use for a parts vehicle.
Here is where the fun begins. Local kid moved out of state when the job was half done. New kid stepped in and tried to fix. To make a long story short I now have a jeep with 10 in front drum brakes and 8 inch back drum brakes. One of the kids changed the back axle shaft back to original so he could hook up the emergency brake. Everyone I have talked to says it shouldn't matter but to me it seems that your brake calipers are different sizes (front to back).
So recently my master cylinder went out so I put a new one on and now my peddle goes to the floor and I have to pump it about 5 times to build up pressure. I have bled it repeatedly over a course of three days. I also bench bled the master a few times as well.
Any thoughts???? Should those effect my stopping in any way?
