    To dismiss this notice
    click the top right X.
axle widths
axle widths
reptile610
st. clair shores, MI
1982 CJ7: 151cu iron duke/ sr-4 trans/ dana 300/ dana 30 front amc 20 rear 3.73 gears.
i think this should be a sticky.
Front Dana 30 .
http://www.jeeptech.com/wiki/index.p.../Front/Dana_30
Specifications
Model/Version Spring Pads Wheel to Wheel Years
Dana 30 /CJ Narrow Track 28" 53" '72-'81
Dana 30 /CJ Wide Track 28" 56" '82-'86
Dana 30 /XJ NA 60 3/4" '84-
Dana 30 /MJ NA NA '86-'92
Dana 30 /YJ 31" 60" '87-'95
Dana 30 /ZJ NA NA '93-
Dana 30 /TJ NA NA '97-
Rear Dana 44 .
http://www.jeeptech.com/wiki/index.p...y/Rear/Dana_44
Specifications
Dana 44 /CJ Narrow Track 28" 50.5" '50-'75
Dana 44 /M38 28" 50.5" '50-'55
Dana 44 /M38A1 28" 50.5" '50-'55
Dana 44 /Willys Wagon NA NA '50-'65
Dana 44 /Willys Pickup NA NA '50-'65
Dana 44 /M170 28" 50.5" '5?-'6?
Dana 44 /FC Truck NA NA '57-'65
Dana 44 /SJ Narrow Track NA 59" '62-'81
Dana 44 /Jeepster Commando 36" 50.5" '62-'73
Dana 44 /J Pickup Narrow Track NA NA '63-'81
Dana 44 /J Pickup Wide Track NA NA '82-'87
Dana 44 /SJ Wide Track NA NA '82-'91
Dana 44 /CJ Wide Track 36" 54.5" '86
Dana 44 /XJ NA 60 3/4" '84-
Dana 44 /MJ NA NA '85-'92
Dana 44 /ZJ NA NA '95-
Dana 44 /TJ NA 60" '97-
Rear AMC20 .
http://www.jeeptech.com/wiki/index.p...ry/Rear/AMC_20
Specifications
AMC20 /CJ Narrow Track 36" 50.5" '76-'81
AMC20 /CJ Wide Track 36" 54.5" '82-'86
AMC20 /SJ Narrow Track
AMC20 /SJ Wide Track
Nice. I love that website. Does anyone have a good link for a place that explains why front axles are wider than the rears? I think I understand it, but I would like to read up on it if possible. Thanks.
i never noticed it until you pointed it out :notworthy:
I've never seen a good write-up as to why, but would also like to see one.
I know it has something to do with turning radious and handleing but thats about it.
Heard it was for handling and all around stability, but I have never seen a write up on it. I will try to look for one when I ever get home to a computer. When I was looking for axles I found a Dana 30 wide trac and a Dana 44 rear out of a scout with 3.73s, which are wider than a CJ. I told the owner I would just take the Dana 30 and I told the guy that I didn't want a rear that much wider and wider than the front. He got a little annoyed with me because he wanted to sell the set, but I wasn't messing with geometry. For an off road jeep maybe, but mine is a street jeep too.
Im working on a sticky for gear ratio axle codes and I think this info would fit well with it. Give me a little while and we'll have it posted up. :)
$40.00
  20.0%
