Bad brake booster?
Bad brake booster?
thescot
Central Coast of California
83 CJ7, FI'ed 258, T5, D300, AMC 20 and D35. 06 Tacoma 4wd,98 4Runner 4wd, 97 Ram 2500 V10 & Lance 3000, 01 HD E Glide.
In a previous post I made mention of very weak brakes. Yesterday I noticed when I apply the brakes the rpm goes up about 300 rpm, not momentarily, but as long as I hold the pedal down. Guess Im goin deaf, but I dont hear any vac leaks or hissing like typically experienced on other vehicles Ive had. Sound like the culprit?
:)As mentioned in that other post you need to check the booster, the line and fittings from wherever the vacuum source is coming from..............I would say you do have a vacuum leak somewhere associated with the Booster system.
Sometimes you can use a non flammable liquid and hit the area while running when the brakes are applied. Should not be that hard to find.
:D:D:D:D
