BDS 5 inch YJ springs on my CJ7
Scotty
Katy Texas West of Houston
83 CJ7 4" Lift,33x12.5 BFG Mud,D300,AMC20,D30
258 4.2,5 speed,Weber,8000lb Ramsey Winch,lots of lights,More new parts than you can shake a stick at!
Well I have been looking for some replacement springs for my 83 CJ7 .
I found a set of BDS springs on craigslist bran new for 300 bux. The shop that had them told me that they were 4 inch springs for CJ series. I went to BDS on line and did my homework and figured hell..this is a good deal.
So I drove an hour and a half out found the shop that I might add was nice and clean with a number of jeeps and other 4x4s in being worked on. The springs are new and heavy duty and man they look sweeet! And I even got them for $250 bux.
I got home and figured id call BDS and ask then to give me some info over the phone with the part number on the springs.
As the title states I wound up with 5 inch YJ springs..
So I figured it best to hop on the CJ forum and ask if the YJ springs will work on my CJ..The spring and eye width are 2 1/2 so I know they will fit my shackles. I know many YJ parts will transfer over to the CJ but will the springs fit?
I have spent a year rebuilding this CJ and im rather good when it comes to working on my jeep.. But I have never played with springs other than installing new bushings and such..
Help is much appreciated..:chug:
All of the parts for a Yj spring swap are stock Jeep pieces- just mixed around a little. The rear springs swap right in. For the fronts you need 2 rear C.J. shackle hangers, they are the proper width for the Y.J. springs, and 1 Y.J. spring plate for the front pass. side, and a C.J. rear pass. side spring plate for the front driver side.
With 5 in. of lift your also going to need some extended brake lines, a drop pitman arm and some degree wedges for the rear at the least.
Thanks Pete..
The jeep already has a 4 inch lift,Stainless extended brake lines,and wedges in the rear. Im in need of either a drop pitman or im thinking rod flip. I have all the goodies up front. Big Daddys tie rod and drag link, Superbox and Super pump,Borgenson steering shaft and all the heavy duty mounts.
The more I look at these springs the more Im thinking they will bolt right up the way things are.
Im not sure on the maker of the lift I have but it seems to me everything is already set up to accommodate the YJ springs. Im going to buy new u bolts and hardware new spring plates and rear shackles.
I guess I should nut up and post some photos to give folks a chance to actually see what I have going on.
Sit tight..
Ok.. Here you can see the front end the new springs and the beat up rear end.
By scottspiks at 2011-10-24
