Bell Crank lever won't move
fireaxxe
- Longmont, Colorado
- 1978 CJ5 Renegade, 351 Windsor, T150, Dana 20
The other day my clutch linkage broke and disappeared along the roadside. I pulled the Cj home. After deciding to replace everything I can see involving the clutch I crawled underneath and attempted to pull the bell crank lever to the rear (engaging the clutch) only to find that it would not budge. Unless something is bound up it seems that it should move fairly easily. I put the tranny and Transfer Case in neutral. I'm sure I can MAKE it move but that doesn't seem prudent at this time. Any insight would be very much appreciated.
Pertinent info:
1978 CJ5
351 Winsor
T-150 Tranny
Dana 20 Transfer Case
Pertinent info:
1978 CJ5
351 Winsor
T-150 Tranny
