Bell housing help.
jakeh937
- Petaluma, CA
- '79 Cj5, 258 with Howell Fuel injection kit, T18 with dana 20 Tcase, dana 30 front with Detroit locker, AMC 20 rear with LSD and one piece shafts, Warn 8k winch, 1" body lift, 2" suspension lift, 33 tires
I thought i had 2 of the correct bellhousing but I don't think I do. I have the jeep T-18 . I had a separate bell housing I got on a parts jeep and that one is identical to the one I need to replace but someone, sometime, had JB welded part of the housing back together (where the clutch linkage bolts on) and I'm not to sure if that's safe to run. The other one I thought was a 176 bell housing but some of the holes are blocked off and the fork hole is HUGE compared to what I had. Please help [emoji53]
