Bellhousing problem and oil leak
skinnerrouge
helper
Ooops! I think I posted this in the wrong place:
67 (dana spicer T-18 Transfer Case , Dana 27 front diff; Dana 44 rear diff)
We had jeep checked out after buying it and the very able mechanic told us we had a Transfer Case leak, but no big worry. (Just keep oil in it he says)When we got to our new home, (towed the jeep) we drove the jeep little, and then a few weeks ago we noticed a big blotch of oil under it. Not sure what we are dealing with; or even where to put gear oil if need be LOL. Just trying to get advice until we can find a mechanic here?
Clearly bellhousing is missing a bolt, but shouldn't there be a gasket??
Yipes, and thanks!
Have uploaded photos I think :)
Thanks!
Brenda
Tags:http://www.jeep-cj.com/gallery/files/1/6/0/1/img_1772.jpg
Looks like a rear main.
Hi Brenda, no gasket needed on the bellhousing, the thin metal piece is just a dust cover. It may be the rear main seal on the engine leaking oil, so keep a eye on your oil level. You can pick up a Haynes or Chiltons manual for info and pictures on checking and changing oil in your Transmission & Transfer Case . :chug:
I was looking for this last nite but couldnt find it.:) Have to agree with Coldwater , looks to be a rear main seal. Not very hard to fix. Drain the oil , drop the pan , loosen the main cap , replace the seal , tighten cap to spec. , reinstall pan , add oil , and your done. Get yourself a Haynes manual or Chiltons and follow the instructions. One thing I found though is that you need to put a dab of silicone on each of the "feet" of the gasket for a leak free seal.
well there you go, A lot of the old engines have this problem. It really is a easy, if not time consuming project.
