Bent front shackle
stevr59
hey guys i got a 85 c j7 with a 4" lift and i noticed today my right front shackle is bent... would this cause me problems and if so what kinds?
replace it
nuff said
yes i am planing on replacing it soon. but what i wanted to know is what kinds of symptoms would i be having ?
the fact is i am having problems but not sure if the bent shackle is the cause like one i got bump steering and a very harsh ride. i cant hardly go over 5 mph off road it so bad. i can jump on the bumper and it hardly moves the lift kit is unknown as the po did it.. thinking of re[lacing the lift kit later done the road but not sure if it needs to be replaced. fixing to replace all the shackles soon as i get the cash to do so. hoping may be new shackles will fix the harsh ride.
i am kinda of thinking they put in heaver springs cause it came with a Reese hich so i am thinking they was hauling a boat and may have put stiffer springs if so how would i know if i got heavy or meds springs?how a leaf spring works
as you hit a bump. spring flattens out, shackle moves forward allowing spring to flatten
things that will prevent such
shackle bolts to tight
shocks have to much dampening
shocks to long
something in the way of movement
springs are to heavy for the jeep
your problem is one of those, I would say 98 % chance of one of those.
I am not there and pics will not show me what is happening, video would. so you are going need to go out and figure this one out.
if it is none of those maybe we can think of something else.
oh, 4 inch lift, someone may have used way heavy springs
Your bump steering is because th po never did fix all the steering geometry after the lift.
You have a big bill of issues to deal with, we nnd to start with one item, the shackle. Then we can get the shocks and springs. Once all that is done, we fix the steering. If we go for steering first, it aall changes when we deal with the springs
