Bent Front Spring Question
ASW864
I'm new to this forum and did a quick search but couldn't find an answer, so here's my situation.
I was out trail riding at Gulches last weekend and got into a fight with a tree. The tree won! Not only did I bend my aluminium rim and destroy the front shock but also bent the front drivers side leaf spring.
I took the spring off and put it in my shop press and 'almost' straightened it back.
Before
After
I know the "Correct" answer is to replace both front spring. But...
What I want to know if anyone else has tried to straightened one and what problems (if any) did they have afterwards.
Eventually I would like to put YJ Springs under it, but funds are tight now.
My Jeep has NT axles from a CJ5 , so I'm a little hesitant about lifting it too much.
The bent spring is 2" wide and has 5 leafs.
Stamped number 5355581 (as far as I know they're stock)
Before
After
