bent push rod question, or two
spikey
Ok where to start, I've actually had the jeep parked for a little over 9 months doing quite a bit if work to it. I took out the GM Turbo 400 and put in a T-18 , then added a Holley projecton among other things.
Now in the past I've had some issues with this thing jumping time, and I put in a new timing chain. I had no other issues up till I parked it. And that should bring me current.
I've been having a tough time tuning this Holley kit. Like my mpg was as low as 5mpg at one point, but I was back up to 8mpg and making adjustments between fillups. I've only had the jeep back on the road around 30 days now.
So Thursday morning when I started it up I heard a not so good clicking noise. Saturday I drive it about 20 miles to a friend's to help me tune it a little better.
Well, you could tell when we got it in tune cause that's when the click turned into a smack and bent the push rod. Or so I thought.
I know I'm long winded sorry. But if you look at the picture the rod on the left is what bent, and the lifter is ceased or collapsed. But what I can't figure out is the rocker arm that goes on the right one is loose. Even with the bolt tight. What causes that?
What would be my fix? I am an oddball and have a rebuildable AMC 304 in the garage so I have an extra set of heads I could drop off while I try to fix mine??
Sorry if I'm long winded just try to get everything out there.
Thanks for any info
Thanks for any info
