Best lift for a cj
JosephCj
- Huntington Beach ca
- 1972 Cj5 with a 304 V8 stock all the way around
Than do the rear first.Well I will put two in I just can't afford to do both at once
If you are going to run just one locker you always want to put it in the rear.
If you plan to re-gear your axles it'll cost you less in the long run to go ahead and have both axles done with the new gears and lockers the first time. Unless of course you do the install yourself.
Your '72 should have a Dana 44 rear which will hold up to a locker just fine. Most of the ones I've seen had a 3:73 ratio. Dana 44 have a carrier split at 3:92. If you install a locker for the 3:73 gears and later want to swap to 4:10 or 4:56, your new locker may not work. Just something to think about.
