Bleeding the cooling system-I6
duke94
What's the correct method of bleeding the air from the cooling system? I installed a new water pump, heater core, thermostat and all the hoses. When I started it up I didn't get any coolant flow from the upper hose back into the rad and the temp gauge was going towards the hot. Water does go through the heater core. I assume I have an air bubble at the T-stat or did I missed something.
