blowing oil from crankcase vent
elwood blues
Always Off-Roading Jeeper
- Export, PA
- 1978 CJ7 4.2L Comp Cam & valve train, MC2100 carb, MSD ignition, Dana 30 front, T18 trans, Dana 20 txfr, AMC 20 rear.
Hi everyone,
Thanks to a lot of help from this forum (coldwater ) I successfully installed a MC2150 a couple of months ago. I recently replaced the 2150 with a 2100 from a '72 Mercury Comet, because the 2100 does not have an electric choke, or all of the vacuum lines.
Anyway, this week I noticed that I'm blowing oil out of my crankcase vent. With the carb swap I moved my PCV valve to the rear opening on the valve cover (one line to the charcoal canister and the other side to the carb), and the front opening is a K&N breather filter. I checked it while it was running yesterday, the K&N breather had smoke and oil spitting out of it.
Is my PCV valve shot?
