Body Lift
Body Lift
CJ Ironcity
Pittsburgh, PA
1982 CJ7
I currenty have a 4" suspension lift. I am thinking about putting a body lift on as I think lift shackles are horrible. I am going for a one or two inch body lift. Does anyone have recommendations as to what manufacturer to use and if I should use nylon or aluminum? Thanks.
What size tires are you using? Also with that 4" going down may require a little re configuring angles... (Drive train wise)
I've seen a fair few posts mentioning 1" Body lift kits and 2.5" spring suspension lifts (not shackle)... to run 33's and still be nice and stable / safe..
I'll try to find those and link you over when i get out of this buis. meeting...
They had some nice recommendations for the body lifts types...
~ JR :chug:
I was going to keep the 4" suspension lift, and add a 1" body lift. I was going to Run 33 or 34's. I want to ensure that there is MIN rubbing and lots of clearance.
Good idea, a lot of people have been saying 2 1/2 sup. and 1" bl.
BUT I run 4" sup. and 1" bl with 33"s and come real close to rubbing in the rear
off road. I know 35's would rub on mine.
