Body lift
Without having to search for a conversion chart....what is the standard measurement on those tires?this is good advise i am only trying to get tire clearance i have a 2 and half suspension with 285 x 12.50 tires how much more do you think i need. i do rub when it flexes just alittle bit
33 in tires the charts i found say i should have aleast 4 in so i think i will go with a 2 in body lift that should give me 4 and half should be good
I agree with Jim. I've seen bodies seperate from the frame because of the bolts shearing. Although it takes a good side impact to fracture body mounting bolts, it does happen...and with longer bolts and the body farther from the frame, the chances of it happening are tenfold.anything over an inch and I get real leary over the safety of the finished product, seen to may sheared off bodies because of Highway wrecks due to body lifts.
