Brake bleeding problem
1975 Cj drum brakes, not power assisted
Yesterday, I took the Jeep out. The brakes have been working great, but this time, the pedal went almost to the floor. It was a semi emergency, so I drove the Jeep a little ways like this with no issues rather than the pedal dropping so far down. The jeep did stop, and the pedal did not quite get to the floor. I checked the fluid when I got to my destination, and it was very very low. It did not appear to have exposed the holes to the brake lines, but since I had been driving, you never know if is sloshed around or whatever.
I added fluid and pumped it a couple times, and the pedal appears to have returned to normal. I drove the Jeep again, and the brakes feel good as new.
Now I always thought that you will have good pedal and brakes up until you suck air, then it will drop and get spongy, and even if you add fluid, it won't be normal unless you bleed the brakes.
So, why would my pedal drop if I still had pressure? And why would it return just by adding fluid?
I'm confused, should I do a "just in case" bleed"? Don't really want to unless absolutley necessary, the bleed screws are a pain, and I have to drag the wife outside in the cold.
Any informed advice appreciated!
dave
dave
