Brake Booster Upgrade CJ7
JAG811
A fair way back now I ordered an after market booster and master cylinder for the CJ.
Now, it's not as simple as just bolting it in so I thought I'd put together a thread so that others can do the same if they to have no power assisted brakes.
Things to consider.
After taking some measurements and messing around a little I was positive it wouldn't foul on anything.
Things to consider.
- Size of the booster.
- Clearance from the hood.
- You'll also need some new lines as the booster, and or the extension brackets will push the master cylinder forward.
- It's not a direct bolt on job.
