Brake help
thescot
- Central Coast of California
- 83 CJ7, FI'ed 258, T5, D300, AMC 20 and D35. 06 Tacoma 4wd,98 4Runner 4wd, 97 Ram 2500 V10 & Lance 3000, 01 HD E Glide.
Forgive me if this is the wrong place, but I dont see a home for brake related topics. Non the less...I recently picked up a 83 CJ7 . P/O said the brakes were worked on about 5K ago, rotors, pads,drums & shoes. Seems everything done by this shop who did the brakes was good, however the brakes are extremely weak to the point I have reservations about driving in on the road. Pads and shoes look good, rotors an drums are clean and un grooved, no leaks, no booster/ vacuum leaks. I used a mighty vac to bleed them a few days ago, fresh fluid, the pedal is firm but no way can you come close to a lock the up, more like it slows down, like I have no front brakes. The seller didnt mention anything either or appear to have issue with them. Last stop (no pun) the possibility of the incorrect master cylinder from a different year making insufficient internal pressure from to big of a bore? maybe a bad proportioning valve? Any thoughts?
