Brake light help
DaddySniper75
I ran a wire from my battery to my reverse switch (manual Transmission ), From the switch to the reverse light. I have juice in the ran wire, but it doesn't light up. I thought a ground issue.... So I ran an additional wire from the tail light screw, to the tub. Still doesn't work. The bulb is good, when I hook it to the turn signal wire, it lights up (i think it may be grounding at the turn switch). Any idea to make it work?
