Brake Lines with Drum-Disc Swap
AeroMoto
Planning on doing the drum-disc front swap on my 73. Found a full 78 Dana 30 axle. So my question revolves around brake lines. I've got what I assume to be stock 73 dual bore master cylinder (non-power). Most places I've read that it's a good idea to go with a bigger master cylinder and proportioning valve. So my question is this:
For those that have done this swap, did you replace all the brake lines? I have 2 hard brake lines straight from my master cylinder: one to the front that T's, and a second to the back that T's. If I was to do a different master cylinder and proportioning valve I'd have to basically run new brake lines from the master down to the PV, then from the PV to the T's, correct?
