Brake master cylinder
eatdrinkadam
Hello all. I have a 1985 CJ7 4 cyl. I seem to be having a chronic problem with my brake master cylinder overflow running dry. I already had replaced the master cylinder once due to this problem, but it still seems to persist. Every 2 weeks my brakes will go soft and I will need to refill the reservoir and bleed the brakes for air. I checked around the brake system and did not identify any leaks. I do notice brake fluid tends to over flow and leak around the lid of the reservoir. This happened on both the old and new cylinder.. Perhaps this might be a problem with this type of cylinder? Does anyone else have this problem and have any recommendations? Thanks A
