Brakes Dragging on front....
fire3096
I have a '80 CJ7 with v-8. I converted it to disc all around. Put a brake booster on it 2 years ago. Since then it has been under restoration. I have recently got it running and road worthy, Now the brakes are dragging after it has been run for a little bit. Dragging to the point of stopping the jeep without pressing the pedal. The brake booster holds vacum. When this happened i jacked the jeep up and the front wheels were near lock-up, pulled the check valve from the booster, and the passenger side wheel let loose and turned freely. I am going to check the calipers and lube the slides and baybe the piston bore. Other than that I need some ideas on what could cause this...they worked perfect before i started the resto.....(also no changes to the brake system at all, never broke a line!) Give me some ideas cause I am in the dark at this point......
