Brakes upgrade ??
Bulto
I have a Jeep CJ 1979 Dana 30 & AMC20 rear diff. with stock brakes & OEM Brake Booster.
I need more power in the brakes because I don’t lockup my 33” tires.
I try to upgrade my brake system:
I change the OEM master cylinder with a Corvette 1980 Master Cylinder.
I removed the stock proportioning valve, because it’s leak. It was replaced by a Wildwood Engineering adjustable proportioning valve in the rear brake line to balance the front and rear brakes. The front brake lines had been replaced with a single drop brake line ran directly from the Master Cylinder to a split tee & connected to the front calipers.
After these changes the Jeep stops better, but don’t lock my 33” tires.
Any ideas ???
Thanks for any help!
Any ideas ???
