    To dismiss this notice
    click the top right X.
Broken bell house
Broken bell house
Mikes72cj5
Bridgeport, Wv
1972 cj-5 304 t15a model 20 Dana diffs ? Ratio
Have a 72 CJ5 with busted bell house and top cap on t15a Transmission , want to keep AMC 304 engine but looking for another later model Transmission /transfer combo with Hyd clutch so I don't keep breaking in those tight and twisting situations . Does anyone have any suggestions ??
Any YJ bell housing should bolt up to your AMC 304 so I would think a swap could be made from those parts. The early ones had an internal slave cylinder so you have to pull the tranny/x-case to get at it but later on the slave was on the exterior. I don’t remember off hand when the change was made but in 1995 the hydraulic system was sealed so there was no hose to bleed and little to no adjustment available.
Man I sure thank ya for the info ... Already have a lot of yj combo's located . It was likeulling teeth trying to find original cj parts , not to mention a bit pricey!! Thanks again I may be up and trail riding before long.
$100.00
  50.0%
