camber?
dalefan88
Crazy Sr. Respected Jeeper
when i had the ball joints apart and taking my axle out. some how my camber got thrown off. how do you adjust it? my tire is leaning out on the top.
Sounds like you had a camber shim on your CJ and put it on wrong. Did you see anything like this behind your spindle (where it mounts to the knuckle)?
Or, did your CJ have any ball joint sleeves?
Both are designed to adjust camber in a front diff of a Jeep (dana).
The wedges move the ball-joint off center to adjust your camber. Rotate the shim so the wedge moves the joint into the direction you need to move your wheel. There is really only two directions for the shim to me angled - inboard and out board. Just rotate the shim opposite from where it is now and you should be real close to the correct placement.it has the ones in the red box. my friend said he started to unscrew it and stopped. let me guess, that is what messed it up. how do i move it to get it back to where it should be?
~~~then he said he turned the camber thing cause he didnt know what it was.~~~
