Carb Issues?
phyrph0enix
[1984 Jeep CJ7 AMC 258 i6 / 4.2l , 5 speed, stock wheels/tyres/ride height]
1st issue:
Car ran great! Then bean to miss at idle. Compression test showed about 95psi on every cylinder. Manual turning of the crank showed no rotor spin for ~10º. Rotor could be jiggled up and down about 1/16".
So, that led me to these repairs so far:
NEW:
timing chain and gears
distributor
cap
rotor
plugs
wires
others:
valve cover gasket
F+R pads/shoes/calipers/cylinders/hardware
parking brake cables/hardware
The Nutter Bypass was done by the PO... despite it being a total mess, It looks like he got the basics right.
My new problem:
The car starts on a dime and idles at 8ºBTDC. The vacuum advance works. Also, after I finished with the above repairs it ran flawlessly for about 3 days. Now, it sputters and pops at idle but remains fairly constant at 700rpm (±10). When it's shifted into gear and load is applied, the engine bogs down but will kick on and off jerking the car down the street.
What it feels like:
Calm idle at stop light. Apply clutch, shift into 1st. Release clutch to bite and bring RPMs up. **Popping begins and RPMs drop then shoot way up and the car lurches forward and revs hard them RPMs drop and shoot up again. This occurs through every gear and will fluctuate from bogging to revving about once every 3-5 seconds. The minute load is removed idle resumes and is fairly smooth. Essentially, the car gallops down the road...
Since drafting this novel I've been back out. messed with the carb and now it sputters slightly at idle and wants to bog out even without load applied. This led me to think it's a carb issue.
Any ideas?
Also, can anyone identify this carb? It doesn't look like the "carter bbd" I googled but doesn't say anything on it either. If it's my problem, I'd like to know what I have to rebuild or replace... (so I don't replace it with the same thing...)
1st issue:
NEW:
distributor
cap
rotor
plugs
wires
others:
valve cover gasket
My new problem:
What it feels like:
Any ideas?
