Carbon buildup on half of the sparkplug!
jzak
Old Time Jeeper
Pittsboro, NC
1981 CJ5/258 4.2L I6, Tremec T-176 4-speed, Dana 300, Power Steering, Howell Throttle Body Injection System, Warn Locking Hubs, Warn Rock Crawler front/rear bumper with Tire Swing Carrier, Full Roll Cage, Pro Comp ES9000 shocks
Hey Everybody!
So last time I replaced the spark plugs on my AMC 258 i6 / 4.2l , I noticed something weird. There was carbon buildup, but only on one side of the sparkplug. I looked online, but nobody seemed to have a real answer for what's causing it.
Thanks for any help!
Josh
You haven't been turning your plugs around enough ....... :) ...... around enough ...... ohhh man I crack myself up something fierce ...... :)
Yep.
You're supposed to rotate the spark plugs every 30,000 miles,
Valve stem seals are leaking.I have seen it many times.If your valve guides are also worn it may be time for a reconditioned head. Build up will be toward intake valve. Changing seals only would be a short term fix. mike
What plugs are you using?
BTW-That is normal, if the carbon is DRY.
The carboned side is away from the exhaust valve. ;)
Yes I agree if the carbon is dry. What I was referring to was a oily buildup to the point of fouling the spark plug. I guess the OP will have to figure out that part.
