Carter BBD Idle curb idle adjustment problem and other issues.
Techlight
- Media
- 1
- California desert
- 1984 CJ7: 4.2l i6 (mild cam), Team Rush, Howell TBI, T5, D300, D30-front, AMC20-rear, 33/10.5/15 BFG A/T's........................
1964 Kaiser CJ5 (sold),
1960 Willy's CJ5 (sold)
Hey all
I searched the forums but couldn't come up with anything answering my question.
I live in California so no skipping emissions or OE vacuum etc. General info on jeep: 1984 jeep CJ7 crate motor just installed since PO blew it up after driving it when it was overheating. Actually drove it until it was so hot it was stalling. Anyway...Jeep sat for 5 years brought it home got it started verified blown motor (he wasn't sure).
New motor runs fine actually perfectly (minus the curb idle), when it's cold it idles fine until it steps down to curb idle then it promptly dies. Steps I followed below:
Set the timing according to
Sol-Vac
Set timing fine (9* at 1600) vacuum switch unplugged and distributor advance vacuum plugged.
Reconnected everything double checked timing. Set fast idle on second step (1700rpm but I might have been a tad under) with EGR vacuum plugged.
Reconnected EGR vacuum. Went on to the curb idle. Plugged sol vac vacuum and disconnected wire from harness. Blipped the throttle (not running) to disengage fast idle stepper (this wasn't in the instructions but I could see no way that the curb idle screw would reach the pivot to adjust because well it's the fast idle screw with the stepper, right?).
Either way: curb idle screw will get me to about 350-400 rpm before bottoming out on the pivot and of course will not turn anymore.
Had to stop here before next step. Did I do this correctly? Should I be concerned with the main idle mixture screws at the bottom of carb? The PO was a nice guy, but I really have no idea what he did to this thing...from the looks of the plugs before new motor it was running very rich but the thing was leaking everywhere so who knows really. From reading it seems that I should turn the idle mixture screws all the way in and then out 2-2 1/4 turns, but I would be unclear on how to go about adjusting carb after that. I'm also a littler weary because my Chilton yells at me about those screws (seriously in all CAPS tells me not to touch them. They get their torque values incorrect all the time so I'm unsure if I should listen to them, especially since they're yelling at me
I'm sure it could use a rebuild (just because everything else did), but was hoping to get it running somewhat for a few before I tear into that or take it to a mechanic for a few other emissions tests.
Sorry, long post. Am I doing something wrong with the curb idle? When I read the sticker on my emissions tag it says to set the curb idle first (after timing, but before fast idle) but from the looks of it, that curb idle screw is going to do nothing for me regardless of when I set it.
I tried snapping some photo's but they didn't come out so well in the dark. basically shows fast idle screw set and not sitting on stepper and curb idle screw bottomed out (which gains me a rough idle of about 400 rpm).
Thanks in advance for any help.
Sol-Vac
