caster angle
84 CJ7 , 360 auto. Installed Rough Country 4" Suspension lift with a 1" lift shackle. After the install I took it for a ride and noticed that the steering was very light and wandering a little on the highway. I took it for an alignment and the mechanic said that my caster angle should be 8 degrees and was way off. He recommended that I install a shackle reverse to gain some caster angle and a better ride. After installing the shackle reverse my caster angle went to 5.5 degrees. My mechanic said that he doesn't believe in using shims. I still have light steering and some wandering on the highway. I guess that I need 2 degree shims to get caster at 7.5 degrees which would only be 1/2 degree from what my mechanic said of it should be 8 degrees. Are shims that dangerous? A 2 degree shim wouldn't be very thick to worry about. Any ideas? I just want my jeep to drive straight.
