Checking Tie rods and Drag links
Tidife
- Media
- 5
- Fort Drum, NY
- 1971 CJ-5
"Dauntless" Buick V6 Engine, SM420 Transmission, Dana 18 Transfer Case, 31" Super Swampers. Dana 27 Front, Dana44 rear(two peice),no clue on Lift yet(2-6 inches maybe?)
So after checking my Steering components, I'm starting to get a bit confused.
I have a 1971 CJ5 and my tie rod/drag links look like its from a late model CJ5 instead. It looks identical to the setup in the Troubleshooting & Correcting Steering technical thread, with the exception of a drop pitman arm instead of a regular pitman arm and what i will explain below.
I have a tube that is 35.2" long. It connects from a tie rod end on the driverside wheel to a tie rod end with a hole on the passenger wheel. A tie rod end is connected to the passenger tie rod end with a hole and leads to the drop pitman arm. That tube is 22.5" long and 27" from the tie rod end(connected to the hole in the tie rod end with a hole on the passenger wheel) to the tie rod end connected to the drop pitman arm.
It sounds confusing to me so let me know if it is for you as well.
(Simplified version- Exactly the same as the tech writeup except i have a drop pitman arm and the tie rod ends connect at the passenger wheel as pictured in the attached thumbnail)
I've been checking the lengths of tubes and my Service manual( Universal SM for 53-71 Jeep CJ and DJ) and it doesnt show any of these parts except the tie rod with a hole. I check the 72+ parts list and none of the tubes match these lengths. I was informed by another member that i have a "Saginaw power steering gear box" and thats what connects to the pitman arm.
My assumption is that the change in the steering components were to allow the steering gear box, but that's about it. The tubes look okay, a little rusted but not bent or anything.
The question I have is how i would go about finding out what tie rod ends i need to replace them all? Just dismantle them and check? and as far as removal, i understand that i can just undo the cotter pin, take the castle nut off knock the tie rod end out of the hole(whatever its connected to) and then unscrew it?
If anyone has any advice on this, I'd greatly appreciate it. I've never messed with steering components before and I'd like to start doing it myself, but I'm unsure as to how to go about it as its different than my FSM. Also if anyone can think of other things i can do to improve my steering besides just these tie rod ends I would be thrilled to listen to their advice.
Thanks,
Tidife
Thanks,
Tidife
