    Thank you for your support!
cherokkee to wrangler drivetrain swap
wrangler rider
the south
95 wrangler with 88 4.2 carbed with puguetoe(?) 5spd both fresh rebuilds, spring over, 3inch body, spring arched 2 inches and stiffened, 10 inches of total lift on 36inch tsls 8k mile marker winch, ect.
1969 dodge charger rt se 440, 727 torqueflite 3.55 suregrip with 8 3/4 axle, everyone is making her a headache for me but i love her 1000xs more then my jeep
2005 dodge 3500 cummins 6speed dually work truck, not mine
i have a 95 wrangler 4cly 5 speed both engine and tranny are bad i found a cherokee with a 6cly auto 4x4 for 200$ running and im going to do it, but how hard it is to do that swap?
btw i get the wholetruck for 200$
thanks
i just got the truck where are the motor mounts on the 6cly wralngfers vs 4cly?
