CJ 5 steering column swap.
rushpowersystems
- Media
- 7
- West Jordan Ut
- Yukon, XJ, CJ, and a bad <-BAD WORD-> banna seat schwinn
OK I am 6'2" and 250 LB so an 80 JC5 was probably a dumb purchase, but hey I love to tinker. I don’t know if this has been covered or not (did a search and found nothing) but a pre-air bag, early 90's XJ/MJ steering column is a real easy swap.
I grabbed a tilt column from a 92', it will bolt to the upper column mount bracket, the turn wiring is the same as many 70's and up CJ’s so that may be a plug and play or at least it is easy to rewire. You can grab the control module and use the intermittent wiper on the column and if you find one with cruse control it is a great way to kick on a radiator mister or....what the hell a nos switch! Anyway here is the changes that are needed, cut off the lower mounting flange on the 92 column, cut 1" off the bottom of the shaft and grind a new groove for the steering joint bolt. If your column has ignition in the column the plugs should be the same depending on the years, however I found that my brake pedal hit my IG switch, easy fix is to shim the column down at the fire wall about 1/8" or so. Oh you can also move the dimmer switch to the one in the column as well. Stay tuned photos will follow.
