Engine CJ-7 Intake Recommendations
Owenkc
Valley Center, KS
'86 Cj7 258cu V6, T4 Trans, Unknown Transfer Case and Diff
My Father and I are rebuilding his 1986 CJ7 , I was just wondering if anyone had a good recommendation for an intake without a ton of emissions restrictors. He wants to keep it a 2 barrel carb, its the AMC 258 i6 / 4.2l cu 6 cylinder. Thanks!
The stock intake only had a couple of sensors. The emissions was controlled by computer controling the carb. Put a pre 83 carb on it remove the computer, and you have no emissions. Look up "nutter" and you will find the wiring for the ICM wiring change and you will have a pre 83 engine. No emissions controls.
Here is a diagram https://gleebledorf.com/ignmods.html
Here is all you need to know about the emissions system. https://gleebledorf.com/list.html
