CJ-8, YJ suspension conversion?
porkwhitemeat
So I have an '82 scrambler w/ Dana 30 and AMC20 that I am rebuilding and I have been doing my research on the CJ to YJ spring conversion but I just want to make sure that I have the right parts for this suspension lift as the internet has made it clear as mud for me
Heres my parts list from 4wd.com:
Crown Front spring plates: CRO52040348, CRO52040407
Crown Rear spring plates: CROJ5363439, CROJ5363440
Shackles: DAYKJ61010BK, DAYKJ61011BK (0.5" lift)
Ubolts: KIT4WD603, KIT604
M.O.R.E spring shackle hangers MRESR103 (X2)
M.O.R.E shackle frame mount brackets W/I404 (x2)
and I'm going with YJ OME 2.5" HD's springs F&R, w/ bilstein 5100's.
Also, I am replacing my body mounts so should I go with a 1" body lift to help fit 33's? It will be used primarily on the road with offroading consisting of mountain roads with creek crossings, minor rocks, and kelly humps. I want to keep my factory sway bar as it is going to be on a DD which sway bar disconnects/ext should i go with? I'm open to any suggestions.
