CJ steering box parts - steel return line ??
DHugg
- Media
- 46
- Resources
- 1
- MS Gulf Coast
- '80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
Who has bought (made - stolen - junkyarded) a steel return line and metric fitting with rubber O-ring for an '80 CJ7 power steering box? I have the new steering stuff all installed, but the return line is twisted and fluid passage gotta be restricted.
When I re-installed the pulley, I used red emery cloth in burnishing the pulley shaft on the AGR Performance Super Pump. I made a few passes with a brake cylinder hone down the pulley hub to smooth out some scratches, then wrapped the hone with emery cloth for a minute's polishing. Pressing the pulley onto the hub was quite smooth, but required enough muscle torqueing down the press nut to know the pulley was a tight press fit.
Gulfport, MS, is a small town of about 50,000, and finding a sales person in any of the automotive parts chains who knows what I'm asking for is a bit of a challenge, at least it was today. If I knew which Ford or GM model uses the same power steering pump, I could get one in my hands in half a day, and have the system leak-checked and bled by nightfall.
Anyone have any experience to share out?
