CJ5 front shock relocate
WACJ5
- Benton City, WA
- 1956 CJ5; 231 Buick, T98/T18, Warn overdrive, 33s, Dana 25/44, 5.38 with lockers, 2.5" Softride lift, reversed front shackles, flipped tie rods, line lock
I have a 1956 CJ5 with a clearance problem between the tie rod and shock absorber. I am Limited to right and left turning radius by the tie rod hitting the shock cover. Others suggest I relocate the shocks from the front to the rear of my Dana 25 axle. Are there sources for the frame mount other than custom fabrication? Other suggestions are certainly appreciated as well to gain turning radius.
Thanks. Larry
Thanks. Larry
