CJ5 lift question
Even with a 4" lift you will have to cut the fender wells to make 35's not rub.
Body lifts are not recommended around here much, they are not a good idea as they create a shear point in the mounting hardware.Not necessarily true. Body lifts can help out.
If you know the engine is original then the 7th letter in the vin will be an "H" if this is true the third letter has to be an F, = T-150 3 speed. If the 7th letter is "C" = AMC 258 i6 / 4.2l then the third letter is M = T-18 . Talking original parts here.Posi-I know it is the original engine, I thought it was original Transmission also but it is possible it was swapped at one time. I bought it with the AMC 304 and 4 speed already in it.
