CJ5 several steering column problems
MoparJoel
- Las Vegas, NV
- 1977 CJ-5 -258ci/T-150/Dana20/ FrontAMC20/BackDana30
So today I was going to a Jeep show in my 77 CJ5 , went to turn the key over and it was free spinning the tumbler. so I disassembled the whole wheel and got the tumbler lock out and replaced it with a new one. but that didn't fix it.
So I looked down the whole where the tumbler goes and the rack/sector gear the tumbler driver is broken. So to get it out I started to disassemble the whole column now where one problem occurs is all the bolts are out and i can't separate the outer column from the center shaft its loose as hell but i can't pull it out its hanging on something and i can't see what. does anyone know what I'm missing…
also when i moved the column it turns out my top shaft bearing fell to pieces when i moved it so that is going to have to be replaced along with the rack and sector gear. but first I need to find out how to remove the column to get to the rack and gear. Column is non-tilt floor shift.
